Re: Sharpening jig/grinding answer
Hi Pam
In my opinion, with just one exception, honing guides are best suited to sharpening via micro secondary bevels. It is inefficient - with non-laminated blades - to hone the full face of a bevel.
Only the Sharp Skate is designed to hone full faces. And this was really developed with laminated Japanese blades in mind, an alternative to side-to-side freehand sharpening.
When one freehand sharpens a non-laminated blade, either one creates a hollow grind and uses this as a template to hone, or one lifts the blade when honing. Both methods create a microbevel. The first method does so without a secondary bevel, while the second method relies on it.
All these methods have one thing in common: reduce the amount of steel that needs to be removed in sharpening. The reason that this is not considered necessary with laminated blades is that the layer of hard steel is thin already, and the soft backing layer abrades relatively easily. The point is, here too one is only honing a small section of the bevel.
Messages In This Thread
Sharpening jig/grinding question
Re: Sharpening jig/grinding question
Re: the scots
Re: Efficiency
Efficiency rarely a consideration on this Forum
Very well said. *NM*
Re: A grinder and two stones..
Razor hone questions
Sent you an email, Bill *NM*
Two most useful sharpening tools you can buy
Re: Two most useful sharpening tools you can buy
Amen to the hand lens *NM*
Good points, well stated. Diplomatic, even. *NM*
recommend that lens again.......
Funny you should compare it with your B&L *LINK*
You bet, Bill. Glad you like yours. *LINK*
Re: You bet, Bill. Glad you like yours.
at least sharp enough
Re: You could be plenty sharp to finish plane...
Re: Efficiency
Re: Efficiency
"Riding" hollow bevels on flat sharpening media
Whatever, but it's not inefficient. *NM*
Re: Tradtional Archery
Re: Good analogy! *NM*
Which came first...
Re: Which came first...
Full bevel
Re: Full bevel
My Method
TAANSTAFL
ADMIN! A reminder about civility
Re: A reminder about civility
didn't really answer my question
Re: didn't really answer my question
Flat bevel
Re: Flat bevel
Re: Flat bevel
Re: Flat bevel
chisel wear
Re: Flat bevel
Re: Flat bevel
We have been discussing this topic for years
Re: We have been discussing this topic for years
Sorry, I don't run your tests on command. Bill? *NM*
Re: Sorry, I don't run your tests on command. Bill
Smarm?! Hey, Bill, is this what you had in mind? *NM*
LV's plane blades, as shipped are sharp. *NM*
Yes, that's pretty much it
