Re: "Sherman, set the Way Back machine for... "
David Weaver
Blue steel is much closer to carbon steel (it fails like carbon steel - uniform wear). What gives it durability is more hardness than anything else, i would think. The same thing at 58 hardness wouldn't last that well.
Special cutting steel is maybe getting closer to a high speed steel, but still not there.
Togo inukubi is sometimes called a high speed steel, but my experience with it is that it's closer to a carbon steel in use. I am not about to experiment with finding its temperature resistance. I don't find it similar to HSS to sharpen though.
I don't know about the super blue and the other HSS that japanese maker's use, I've only had special cutting, white #1, #2 and inukubi.
No need for slinging any names or perceptions around at all with old or new steels.
I personally just don't see a reason to not go with something that stays sharp as long as HSS but has carbides no bigger than the particle size, which may be only several microns. It'll wear like HSS but fail like carbon steel - that's an awfully good combination.
Messages In This Thread
CPM 3V vs. CPM M4 ?
Aaaaaaaaaaahhhhhhhhhhhhh!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: Aaaaaaaaaaahhhhhhhhhhhhh!!!!!!!!!!!!!!!!!!!!!!
Re:Length of thread
Re:Length of thread
How do you sharpen your nib,Marv? *NM*
Re: How do you sharpen your nib,Marv?
What good would a short answer do? :D *NM*
Yet another new metal (long)
Priceless
Way to go Bill !
(Message Deleted by Poster)
Re: Sticks and stones... sounds like woodworking
Re: Bravo!
Re: Bravo!
Christ all mighty...
Finally!
So...
Your moderator, reading this subthread... *NM* *PIC*
But Bee-wee,we wuv you...
Re: But Bee-wee,we wuv you...
"...but I know he does..."
We do what we can
Re: CPM 3V vs. CPM M4 ?
that is the problem
to repeat a chisel dulling discussion
Re: to repeat a chisel dulling discussion
I`m just happy...
Wait...
Metals
Re: Metals
must consider the whole process
Re: Metals
Re: Metals
As my dentist once said...
Bring on the Novocaine! A brief missive.
Cr-V question, then...
Re: Cr-V question, then...
realize significant gains???
View from the peanut gallery
In a nutshell (well, for me, anyway)
hardness, toughness
Re: hardness, toughness
could you explain the numbers?
You bet.
Re: You bet.
Re: You bet.
Re: You bet.
Re: You bet.
Where on earth? What on earth? Huh? Say whuh?
Since when has mass acceptance and ...
Re: Since when has mass acceptance and ...
Those are the numbers! *LINK*
Re: Those are the numbers!
I'm confused, Warren
Re: I'm confused, Warren
I'm impressed!
Re: I'm impressed!
Why diamond wheels aren't used to grind steel
Re: diamond wheels - that's what I was after
Grinding Temperatures
Steve knows stuff.
Diamond wheels? Who brought up diamond wheels?
Re: Diamond wheels? Who brought up diamond wheels?
Your closing line reminds me of Dan O'Neill,
There I went again.
Re: There I went again.
Well, I was thinking about a diamond wheel. :) *NM*
Re: The diamond and HSS thing...
It's not so much a file protection thing as a... *LINK*
Just out of curiosity,
Re: Just out of curiosity,
Can you expand this thought Warren?
Good catch! *LINK*
Aim Hardness for 3V
Interesting and valuable *LINK*
3V Heat Treatment Schedule
Very helpful, Steve
Cryo
"How ya gonna keep 'em down on the farm... "
The good stuff
I like bacon. :@) *NM*
Re: I like bacon. :@)
Gotta agree Warren
Re: The good stuff
Re: The good stuff
Re: "How ya gonna keep 'em down on the farm... "
Heat treating -- the simple and not so simple
Re: Heat treating -- the simple and not so simple
Tom's right, Pam -- but wait! There's more! *LINK*
Re: Tom's right, Pam -- but wait! There's more!
Steps to completion
Thanks, Bob, understood. *NM*
Work hardening?
Re: Work hardening?
"All your base are belong to us"
Re: realize significant gains???
BTW #2
Re: BTW #2
Suggestions Larry? *NM*
Let he who is without sin...
A model for decision-making
Re: Bring on the Novocaine! A brief missive.
Hi, Andrew! (and a couple things I left out above)
Re: Hi, Andrew! How do they make ...
Here ya go, George. *LINK*
Re:Thanks David, now I know.... *NM*
Different worlds,different approaches
Re: As my dentist once said...
Tow truck? Who needs a tow truck? *LINK*
Re: Tow truck? Who needs a tow truck?
Oh, see? I handed you a straight line back :D *NM*
Re: Metals
Re: Metals
Re: Metals
Re: Metals
