Re: Tom's right, Pam -- but wait! There's more!
TomD
1) I start with biggest piece of steel I can buy, because it is a lot cheaper, but with 3V I don't know if this applies, or in your case due to the size of your project.
2) mark it out, I normally just use pencil or marker.
3) saw out on bandsaw with bimetal blade, or use hacksaw.
4) File or grind past the saw-out marks, going a little past is good because the marks will appear to vanish while there can still be a stress riser there.
5) Grind bevel, or file. The Nicholson Magicut file is well regarded for hand filing tools and knives. With O1 one needs to leave about 1/16" bluntness at the edge for heat treating. The final grind is done after heat treating. I don't know what the edge thickness should be for 3v.
6) Since the whole blade will be hardened, if you send it out to a heat treated, you need to finish the whole blade to final finish both to avoid stress risers that might cause trouble if you left rough marks, and because any marks will be a lot harder to shift after the blade is hardened. So break edges, cut radiused ends if any, stamp or cut makers mark, and finish sand the surfaces.
7) Most heat treaters want a small hole to hang the part from in the oven. This needs to be drilled before you send the blade out (probably before 6). Though 3v needs to be wrapped in foil and maybe they don't need a drill hole, something to ask about when contacting your HT shop.
Messages In This Thread
CPM 3V vs. CPM M4 ?
Aaaaaaaaaaahhhhhhhhhhhhh!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: Aaaaaaaaaaahhhhhhhhhhhhh!!!!!!!!!!!!!!!!!!!!!!
Re:Length of thread
Re:Length of thread
How do you sharpen your nib,Marv? *NM*
Re: How do you sharpen your nib,Marv?
What good would a short answer do? :D *NM*
Yet another new metal (long)
Priceless
Way to go Bill !
(Message Deleted by Poster)
Re: Sticks and stones... sounds like woodworking
Re: Bravo!
Re: Bravo!
Christ all mighty...
Finally!
So...
Your moderator, reading this subthread... *NM* *PIC*
But Bee-wee,we wuv you...
Re: But Bee-wee,we wuv you...
"...but I know he does..."
We do what we can
Re: CPM 3V vs. CPM M4 ?
that is the problem
to repeat a chisel dulling discussion
Re: to repeat a chisel dulling discussion
I`m just happy...
Wait...
Metals
Re: Metals
must consider the whole process
Re: Metals
Re: Metals
As my dentist once said...
Bring on the Novocaine! A brief missive.
Cr-V question, then...
Re: Cr-V question, then...
realize significant gains???
View from the peanut gallery
In a nutshell (well, for me, anyway)
hardness, toughness
Re: hardness, toughness
could you explain the numbers?
You bet.
Re: You bet.
Re: You bet.
Re: You bet.
Re: You bet.
Where on earth? What on earth? Huh? Say whuh?
Since when has mass acceptance and ...
Re: Since when has mass acceptance and ...
Those are the numbers! *LINK*
Re: Those are the numbers!
I'm confused, Warren
Re: I'm confused, Warren
I'm impressed!
Re: I'm impressed!
"Sherman, set the Way Back machine for... "
Re: "Sherman, set the Way Back machine for... "
Why diamond wheels aren't used to grind steel
Re: diamond wheels - that's what I was after
Grinding Temperatures
Steve knows stuff.
Diamond wheels? Who brought up diamond wheels?
Re: Diamond wheels? Who brought up diamond wheels?
Your closing line reminds me of Dan O'Neill,
There I went again.
Re: There I went again.
Well, I was thinking about a diamond wheel. :) *NM*
Re: The diamond and HSS thing...
It's not so much a file protection thing as a... *LINK*
Just out of curiosity,
Re: Just out of curiosity,
Can you expand this thought Warren?
Good catch! *LINK*
Aim Hardness for 3V
Interesting and valuable *LINK*
3V Heat Treatment Schedule
Very helpful, Steve
Cryo
"How ya gonna keep 'em down on the farm... "
The good stuff
I like bacon. :@) *NM*
Re: I like bacon. :@)
Gotta agree Warren
Re: The good stuff
Re: The good stuff
Re: "How ya gonna keep 'em down on the farm... "
Heat treating -- the simple and not so simple
Re: Heat treating -- the simple and not so simple
Tom's right, Pam -- but wait! There's more! *LINK*
Steps to completion
Thanks, Bob, understood. *NM*
Work hardening?
Re: Work hardening?
"All your base are belong to us"
Re: realize significant gains???
BTW #2
Re: BTW #2
Suggestions Larry? *NM*
Let he who is without sin...
A model for decision-making
Re: Bring on the Novocaine! A brief missive.
Hi, Andrew! (and a couple things I left out above)
Re: Hi, Andrew! How do they make ...
Here ya go, George. *LINK*
Re:Thanks David, now I know.... *NM*
Different worlds,different approaches
Re: As my dentist once said...
Tow truck? Who needs a tow truck? *LINK*
Re: Tow truck? Who needs a tow truck?
Oh, see? I handed you a straight line back :D *NM*
Re: Metals
Re: Metals
Re: Metals
Re: Metals
