Re: hardness, toughness
hardness, toughness ()
Phil Smith
Normally you can get one but not both at the same time. Some results from the cloud.
O1 typically as quenched HRC 65.
Temper; HRC; Charpy C-Notch ft-lbs
300 F; 64; 14
350 F; 63; 28
400 F; 62; 30
450 F; 61; 30
500 F; 59; 30
600 F; 56; 32
Based on this data O1 has nice broad range of hardness with reasonable toughness.
CPM 3V typically as quenched HRC 65
58; 85
60; 70
62; 40
At HRC of 60 CPM 3V has about 2X the charpy notched impact that O1 has and is about 1/3 better at HRC 62. Hence the intial choice for chisels and plane irons.
CPM M4 typically as quenched HRC 60 to 65 depending on heating and quenching schedule. Some selected data on hardness and toughness follow. Based on literature there is broad range of schedules to get blend of hardness and toughness depending on end use application.
HRC; Charpy C-notch impact values ft-lbs
65.5; 20
63.5; 28
62; 32
Next batch of tools i make will likely be made of CPM M4 hardened to HRC of about 63.
A2 as quenched from 1775 F, HRC 64f.
HRC; Charpy C-notch ft-lbs
61; 31
60; 41
59; 37
58; 33
Based on the data i've seen in the literature A2 toughness drops off very fast above HRC 61. From some of the graphs I've seen looks like about 50% drop going from HRC 61 to 62, hence some of the chipping issues we've seen report with chisels at HRC 62.
Messages In This Thread
CPM 3V vs. CPM M4 ?
Aaaaaaaaaaahhhhhhhhhhhhh!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: Aaaaaaaaaaahhhhhhhhhhhhh!!!!!!!!!!!!!!!!!!!!!!
Re:Length of thread
Re:Length of thread
How do you sharpen your nib,Marv? *NM*
Re: How do you sharpen your nib,Marv?
What good would a short answer do? :D *NM*
Yet another new metal (long)
Priceless
Way to go Bill !
(Message Deleted by Poster)
Re: Sticks and stones... sounds like woodworking
Re: Bravo!
Re: Bravo!
Christ all mighty...
Finally!
So...
Your moderator, reading this subthread... *NM* *PIC*
But Bee-wee,we wuv you...
Re: But Bee-wee,we wuv you...
"...but I know he does..."
We do what we can
Re: CPM 3V vs. CPM M4 ?
that is the problem
to repeat a chisel dulling discussion
Re: to repeat a chisel dulling discussion
I`m just happy...
Wait...
Metals
Re: Metals
must consider the whole process
Re: Metals
Re: Metals
As my dentist once said...
Bring on the Novocaine! A brief missive.
Cr-V question, then...
Re: Cr-V question, then...
realize significant gains???
View from the peanut gallery
In a nutshell (well, for me, anyway)
hardness, toughness
could you explain the numbers?
You bet.
Re: You bet.
Re: You bet.
Re: You bet.
Re: You bet.
Where on earth? What on earth? Huh? Say whuh?
Since when has mass acceptance and ...
Re: Since when has mass acceptance and ...
Those are the numbers! *LINK*
Re: Those are the numbers!
I'm confused, Warren
Re: I'm confused, Warren
I'm impressed!
Re: I'm impressed!
"Sherman, set the Way Back machine for... "
Re: "Sherman, set the Way Back machine for... "
Why diamond wheels aren't used to grind steel
Re: diamond wheels - that's what I was after
Grinding Temperatures
Steve knows stuff.
Diamond wheels? Who brought up diamond wheels?
Re: Diamond wheels? Who brought up diamond wheels?
Your closing line reminds me of Dan O'Neill,
There I went again.
Re: There I went again.
Well, I was thinking about a diamond wheel. :) *NM*
Re: The diamond and HSS thing...
It's not so much a file protection thing as a... *LINK*
Just out of curiosity,
Re: Just out of curiosity,
Can you expand this thought Warren?
Good catch! *LINK*
Aim Hardness for 3V
Interesting and valuable *LINK*
3V Heat Treatment Schedule
Very helpful, Steve
Cryo
"How ya gonna keep 'em down on the farm... "
The good stuff
I like bacon. :@) *NM*
Re: I like bacon. :@)
Gotta agree Warren
Re: The good stuff
Re: The good stuff
Re: "How ya gonna keep 'em down on the farm... "
Heat treating -- the simple and not so simple
Re: Heat treating -- the simple and not so simple
Tom's right, Pam -- but wait! There's more! *LINK*
Re: Tom's right, Pam -- but wait! There's more!
Steps to completion
Thanks, Bob, understood. *NM*
Work hardening?
Re: Work hardening?
"All your base are belong to us"
Re: realize significant gains???
BTW #2
Re: BTW #2
Suggestions Larry? *NM*
Let he who is without sin...
A model for decision-making
Re: Bring on the Novocaine! A brief missive.
Hi, Andrew! (and a couple things I left out above)
Re: Hi, Andrew! How do they make ...
Here ya go, George. *LINK*
Re:Thanks David, now I know.... *NM*
Different worlds,different approaches
Re: As my dentist once said...
Tow truck? Who needs a tow truck? *LINK*
Re: Tow truck? Who needs a tow truck?
Oh, see? I handed you a straight line back :D *NM*
Re: Metals
Re: Metals
Re: Metals
Re: Metals
