Messages Archive
Re: dittoResponse To:
ditto () Jim O'Connor
That's why I run anything bigger than 3 in. through the table saw with a thin kerf blade to reduce the amount the bandsaw has to cut to a minimum. That may not be resawing but I can get some fairly thin pieces with small amount of waste to be planed off. I usually try to tension my old Delta 14 in. made in 1947 according to the serial no. till the blade flutter stops with all the guides backed off with any width of blade.
