Messages Archive
Re: Just what I needed
Just what I needed ()
John McGaw
Yes. You definitely want the relay(s) and switch(es). These will eliminate the need for heavy wiring going through the firewall. On my last install (many moons ago) I mounted the relays for the two sets of lights right up front beside the radiator and ran the hot leads via inline fuse holders straight from the + post on the battery to keep the voltage drop to a minimum. Of course if you are using LED lights then the current draw won't be nearly as bad as what I had to put up with using halogen lamps.
