Messages Archive
Re: Cherry T&G flooring
Re: Cherry T&G flooring ()
Stiffness not an issue. Air access to both sides critical to success. Finish both sides to slow moisture changes.
If you don't know them, look up "table top fasteners". An abundance of these across the ends will help hold it flat and enable seasonal change, which will be considerable. This top will be easily flexible across its width. Easy to hold down so long as it can slide in the holders.
