Messages Archive
Re: Butcher Block Top Reglue
Butcher Block Top Reglue ()
Dick Coers
Is it completely split off, or just a crack? I have no idea how you can get inside the joint and wipe it off if it's a crack. Solvent will thin the contamination and will also drive it into the pores of the wood. Can't imagine glue sticking at all, especially water based adhesives. A more permanent option would be to cut through the split on the table saw, then glue it back together.
