Messages Archive
I agree with Bill,
Keith Newton
I don't recall seeing any mention of your blade length, so I have no way of choosing a blade for you. However, whatever blade you choose should not have more than 1 TPI. If the saw still has the stock motor, I believe I've read that they are a bit underpowered, so fewer teeth would allow faster feed. Blades last longer if each tooth can take larger chips. Larger chips take the heat out with it, whereas having to feed slower while making finer dust allows heat buildup that dulls the blades quicker.
