Messages Archive
Re: How would you cut this piece?
Dick Coers
First I put down meticulous layout lines, cut off the line on the bandsaw, then trimmed to the line with a pattern bit and straightedge with a router. That was the master. Then cut wide of the layout lines again on the other pieces, and then used the master to trim the next pieces all around with a pattern bit in the router.
