Messages Archive
marking the cut lines
hand saw ()
Tilt the cone. provide a surface parallel to the plane it will set on. Use this surface (plane in geometry terms), a table top as an example, to mark the cut lines. Obviously you will have to rig "table tops" at the heights you need.
