Messages Archive
Re: Lighting for sanding.
Lighting for sanding. ()
AZ in Colorado Springs
You can just use a drop cord. With your head 12 - 18" from the surface you are sanding, hold the drop cord ahead of you at arm's length, at the same height above the board. The light will reflect at a low angle (maybe 30° or so?) and scratches and other sanding imperfections -- such some snipe that's not yet sanded away-- will show up well.
