Messages Archive
Re: Alternative ideas.
Alternative ideas. ()
Tom Is correct about the TS. Part of the problem is using it to break down plywood. It's the sheet of plywood that takes up the space.
I have a TS set up in a one car garage. the blade is five feet from the garage door. If I need to rip anything bigger I open the door.
The problem with a track saw is that you still have to have saw horses of some sort of work table and the room to lay out the plywood. I have a track saw and have not gotten used tot he idea of breaking down the plywood out doors.
I used a Dewalt portable table saw and it was OK. I was remodeling a house and it worked fine for that. the dust collection on it worked pretty well with a shop vac.
Check out Craig's list and buy a used saw.
