Messages Archive
Re: I was thinking about that....
Keith Newton
While I’ve done larger stacks, i would suggest that you try to keep it down to smaller batches if maybe 100 bf at first, or until warmer weather. The heat comes up rather slowly as the moisture evaporated, then a little quicker toward the end with this mild heat. You don’t want to take it too fast, which would likely cause small surface checks.
