Messages Archive
suggestion
Re: Some sage advice ()
Presuming you have some extra lumber glue up a small cutting board, say 10 x 12 inches by the thickness of the island to get an idea of what is involved with keeping pieces in registration and under uniform pressure as the clamps are applied.
Franklin recommends 200-300 psi clamp pressure for maple for the glue you are using. All but a thin layer of glue must be squeezed from the joint. Anywhere there is a thick glue line will be weak. Glue is about 40% solids. If a thick layer dries the result is 40% glue and 60% air, or "Styrofoam", which has no strength and the overhand will easily break off.
Messages In This Thread
Help with a butcher block top
glue appplication information
Re: glue appplication information
I answered this question in my first reply
Re: I answered this question in my first reply
Are you just adding one board for each glue-up?
Walk before you run
Re: Walk before you run
$12/bdft for 8/4 hard maple? Wow! *NM*
A couple of questions....
Re: A couple of questions....
Some sage advice
More explanation....
Re: More explanation....
Tool to smooth the top??
Knots - character or trouble?
Re: Knots - character or trouble?
All planes need the same skills
Might cause issues? You ever use a hand plane?
Re: Might cause issues? You ever use a hand plane?
Re: He is running lengthwise
Yeah, but.....
Re: Yeah, but.....
Wandering OT
suggestion
Re: suggestion
Save yourself a lot of trouble *PIC*
Re: Save yourself a lot of trouble
Re: Help with a butcher block top
Re: Alternating Clamps
fatal and near fatal errors
Agree...
Re: Agree... *PIC*
weight issue
Re: weight issue
test it
More on clamping
Massive
