Messages Archive
Re: Agree... *PIC*
Agree... ()
I like to use steel if there is any question.
The only time I worried about a 12" overhang when building my kitchen. I wanted an 18" granite bar on top of a short separating wall framed from 2x6 lumber. I envisioned some lively person jumping up to sit on the top but instead bringing the thing down, or at least cracking the granite. But I didn't want visible supports.
I built a frame under the granite from hickory and two layer of 3/4" hardwood plywood. A steel channel embedded in 2x6 framing gave a horizontal support to four L-shaped steel brackets I welded from heavy-wall channel and carefully designed diagonal supports. A 1/2" bolt with locknuts let me adjust each bracket to be perfectly level. All hardware was embedded in the wood. 14 years now with no issues.
Messages In This Thread
Help with a butcher block top
glue appplication information
Re: glue appplication information
I answered this question in my first reply
Re: I answered this question in my first reply
Are you just adding one board for each glue-up?
Walk before you run
Re: Walk before you run
$12/bdft for 8/4 hard maple? Wow! *NM*
A couple of questions....
Re: A couple of questions....
Some sage advice
Re: Some sage advice
More explanation....
Re: More explanation....
Tool to smooth the top??
Knots - character or trouble?
Re: Knots - character or trouble?
All planes need the same skills
Might cause issues? You ever use a hand plane?
Re: Might cause issues? You ever use a hand plane?
Re: He is running lengthwise
Yeah, but.....
Re: Yeah, but.....
Wandering OT
suggestion
Re: suggestion
Save yourself a lot of trouble *PIC*
Re: Save yourself a lot of trouble
Re: Help with a butcher block top
Re: Alternating Clamps
fatal and near fatal errors
Agree...
Re: Agree... *PIC*
weight issue
Re: weight issue
test it
More on clamping
Massive
