Messages Archive
Re: Alternating Clamps
Re: Alternating Clamps ()
Garth
Thanks
Glad to hear supports will only be decorative.
I could of use some of your ideas to get the clamps to alternate but won’t having the wood up in the air make it hard to get it relatively flat to start? I would have thought building it face down on a flat surface so I could tap down the boards would be a good thing. Not so? If I can get it as level as the floor is I’d likely be happy.
If I need to take off some wood would a good hand planer do it?
I have a couple of pipe clamps but will mostly be using these 2x4 clamps. They seem to work well.
https://www.stanleytools.com/products/hand-tools/clamps-vises/spring-metal-angle/2-in-x-4-in-clamp/stht83166
I may be bitting off more than I want but for the $150 the wood cost me I’ll give it a try.
Thanks for the help.
Messages In This Thread
Help with a butcher block top
glue appplication information
Re: glue appplication information
I answered this question in my first reply
Re: I answered this question in my first reply
Are you just adding one board for each glue-up?
Walk before you run
Re: Walk before you run
$12/bdft for 8/4 hard maple? Wow! *NM*
A couple of questions....
Re: A couple of questions....
Some sage advice
Re: Some sage advice
More explanation....
Re: More explanation....
Tool to smooth the top??
Knots - character or trouble?
Re: Knots - character or trouble?
All planes need the same skills
Might cause issues? You ever use a hand plane?
Re: Might cause issues? You ever use a hand plane?
Re: He is running lengthwise
Yeah, but.....
Re: Yeah, but.....
Wandering OT
suggestion
Re: suggestion
Save yourself a lot of trouble *PIC*
Re: Save yourself a lot of trouble
Re: Help with a butcher block top
fatal and near fatal errors
Agree...
Re: Agree... *PIC*
weight issue
Re: weight issue
test it
More on clamping
Massive
