Messages Archive
Re: Help with a butcher block top
Dick Coers
No such thing as flat basement floor over 8'. It doesn't have to be level as you mentioned, just a flat plane, and you won't get that. You are going to need filler at the end tongue and grooves since they don't fit tightly to full depth. You'll need more that a random orbit sander to bring all the laminations even close to being flat. You'll have more than 1/16" of wood to take off in some places. You'll also not have a flat top with clamps only on one side, especially if using pipe clamps. The pipes bend with force and the top will have a cup. Cover some 2x4s with plastic and glue up the flooring on top of that. Then you can get clamps under it. Don't put the cart before the horse and worry about the support. You have a LOT of work ahead to just get the slab made.
Messages In This Thread
glue appplication information
Re: glue appplication information
I answered this question in my first reply
Re: I answered this question in my first reply
Are you just adding one board for each glue-up?
Walk before you run
Re: Walk before you run
$12/bdft for 8/4 hard maple? Wow! *NM*
A couple of questions....
Re: A couple of questions....
Some sage advice
Re: Some sage advice
More explanation....
Re: More explanation....
Tool to smooth the top??
Knots - character or trouble?
Re: Knots - character or trouble?
All planes need the same skills
Might cause issues? You ever use a hand plane?
Re: Might cause issues? You ever use a hand plane?
Re: He is running lengthwise
Yeah, but.....
Re: Yeah, but.....
Wandering OT
suggestion
Re: suggestion
Save yourself a lot of trouble *PIC*
Re: Save yourself a lot of trouble
Re: Alternating Clamps
fatal and near fatal errors
Agree...
Re: Agree... *PIC*
weight issue
Re: weight issue
test it
More on clamping
Massive
