Messages Archive
Re: Help with a butcher block top
I agree with everything Bill said, except I might be more concerned about tipping.
If the long side project over the support about 1/3 of the total width, I think its a concern. My calculation is the top will weigh about 150 pounds. That means about 100 pounds is on the cabinets and 50 is overhanging. So if someone leans on it or sits on it, it could tip. Some short brackets underneath would change the dynamics of that completely. Say two or three 6" struts. Or fasten it to the "far side" securely. I would be slightly concerned that someone resting or sitting on the overhang might break one of the joints and the 12" wide piece fall off. (Unlikely, but painful)
If you have a surfacer I would consider gluing up a "surfacer" width piece, skip a glue joint, add another with, Etc. That way, when you take the clamps off you will have about three pieces you could run through your planer. Keep them in order so the glue joints will then work perfectly. utting the three pieces together might be a good application for biscuits or Dominoes. Or dowels or splines, or just be careful.
It will be necessary to turn one edge piece around to avoid leaving the grooves exposed on one side or making that strip thinner.
On the ends, to hide the grooves, you could "celebrate" them. Drill every one of them round and insert a either matching or contrasting dowel plug. Most common dowels are either maple or birch, they should match reasonably well.
Messages In This Thread
glue appplication information
Re: glue appplication information
I answered this question in my first reply
Re: I answered this question in my first reply
Are you just adding one board for each glue-up?
Walk before you run
Re: Walk before you run
$12/bdft for 8/4 hard maple? Wow! *NM*
A couple of questions....
Re: A couple of questions....
Some sage advice
Re: Some sage advice
More explanation....
Re: More explanation....
Tool to smooth the top??
Knots - character or trouble?
Re: Knots - character or trouble?
All planes need the same skills
Might cause issues? You ever use a hand plane?
Re: Might cause issues? You ever use a hand plane?
Re: He is running lengthwise
Yeah, but.....
Re: Yeah, but.....
Wandering OT
suggestion
Re: suggestion
Save yourself a lot of trouble *PIC*
Re: Save yourself a lot of trouble
Re: Alternating Clamps
fatal and near fatal errors
Agree...
Re: Agree... *PIC*
weight issue
Re: weight issue
test it
More on clamping
Massive
