Messages Archive
Re: Help with a butcher block top
Yonak
I believe the overhangs will be a problem, especially on the side in the orientation across the boards. I would plan for supports every 18".
Like Don, I wonder how you intend to surface this behemoth. You're going to need plenty of help as it will be heavy.
If you don't go with Bill's advice to glue the boards a few at a time, you may consider slow-set glue.
If clamping is an issue, you could drill holes through each piece and run threaded rods through the holes. These could stay in place to maintain good support and to prevent separation, attaching end pieces to cover the rod ends.
You could bolt the island to the floor to prevent tipping which, I agree with George, would be an issue.
Good luck with this and show pictures.
Messages In This Thread
glue appplication information
Re: glue appplication information
I answered this question in my first reply
Re: I answered this question in my first reply
Are you just adding one board for each glue-up?
Walk before you run
Re: Walk before you run
$12/bdft for 8/4 hard maple? Wow! *NM*
A couple of questions....
Re: A couple of questions....
Some sage advice
Re: Some sage advice
More explanation....
Re: More explanation....
Tool to smooth the top??
Knots - character or trouble?
Re: Knots - character or trouble?
All planes need the same skills
Might cause issues? You ever use a hand plane?
Re: Might cause issues? You ever use a hand plane?
Re: He is running lengthwise
Yeah, but.....
Re: Yeah, but.....
Wandering OT
suggestion
Re: suggestion
Save yourself a lot of trouble *PIC*
Re: Save yourself a lot of trouble
Re: Alternating Clamps
fatal and near fatal errors
Agree...
Re: Agree... *PIC*
weight issue
Re: weight issue
test it
More on clamping
Massive
