Messages Archive
Re: Help with a butcher block top
Don Stephan
Some questions.
1. Have you clamped together the stack of boards and tried to move it?
Calculate the final weight of the top. How do you plan to move that weight, and are you comfortable with that weight cantilevered the full length of one side about 36" off the floor. Seems like it would do tremendous damage if it were to fall on a leg or even worse a child. Kitchen cabinets are not designed to support that kind of weight, so why would you think this design will not fail.
2. How are you going to dress the six surfaces after all is glued up, to remove squeezeout, glue stain, and slippage.
3. What will keep the initial glueup of two or more boards free of cup and/or twist? A strong straight clamping caul on each side would seem in order, not only to keep the lamination flat and straight but also to even out clamping pressure.
4. Are you planning to dry run of the initial glue-ups?
5. Are you planning a test of the final assembly? Put the cabinets together as planned, clamp the stack of boards together, position as planned on top of the cabinets, and from a distance test the stability.
Messages In This Thread
glue appplication information
Re: glue appplication information
I answered this question in my first reply
Re: I answered this question in my first reply
Are you just adding one board for each glue-up?
Walk before you run
Re: Walk before you run
$12/bdft for 8/4 hard maple? Wow! *NM*
A couple of questions....
Re: A couple of questions....
Some sage advice
Re: Some sage advice
More explanation....
Re: More explanation....
Tool to smooth the top??
Knots - character or trouble?
Re: Knots - character or trouble?
All planes need the same skills
Might cause issues? You ever use a hand plane?
Re: Might cause issues? You ever use a hand plane?
Re: He is running lengthwise
Yeah, but.....
Re: Yeah, but.....
Wandering OT
suggestion
Re: suggestion
Save yourself a lot of trouble *PIC*
Re: Save yourself a lot of trouble
Re: Alternating Clamps
fatal and near fatal errors
Agree...
Re: Agree... *PIC*
weight issue
Re: weight issue
test it
More on clamping
Massive
