Messages Archive
Re: Help with a butcher block top
Kneale Brownson
I did this with oak flooring, only about half the length. Because of the bottom grooves showing in the ends, I opted to surround the block with some trim cut from the same wood that covered the top of the higher holes but did not come to the top surface level. Mine is afastened to the supporting cabinet with Z-shaped tabletop anchors..
Messages In This Thread
glue appplication information
Re: glue appplication information
I answered this question in my first reply
Re: I answered this question in my first reply
Are you just adding one board for each glue-up?
Walk before you run
Re: Walk before you run
$12/bdft for 8/4 hard maple? Wow! *NM*
A couple of questions....
Re: A couple of questions....
Some sage advice
Re: Some sage advice
More explanation....
Re: More explanation....
Tool to smooth the top??
Knots - character or trouble?
Re: Knots - character or trouble?
All planes need the same skills
Might cause issues? You ever use a hand plane?
Re: Might cause issues? You ever use a hand plane?
Re: He is running lengthwise
Yeah, but.....
Re: Yeah, but.....
Wandering OT
suggestion
Re: suggestion
Save yourself a lot of trouble *PIC*
Re: Save yourself a lot of trouble
Re: Alternating Clamps
fatal and near fatal errors
Agree...
Re: Agree... *PIC*
weight issue
Re: weight issue
test it
More on clamping
Massive
