Messages Archive
Re: Help with a butcher block top
John in NM
This is about the most labor intensive way of building a maple top, but it will work well enough it you're getting such a deal on the flooring that its worth all the work it will take.
I'm assuming the flooring is unfinished? You will also have two cut outs running down the underside of the flooring - all the solid flooring I've ever seen has those.
It won't be a problem for reduced gluing surface, but it does present you with a kind of ugly end with all those gaps showing.
One thing I've found gluing up a bunch of pieces like this is that it can be a real pain to do neatly. As Bill said, the easiest way around that problem is to have a long jointer so you can keep things straight.
I would fasten this thing to the floor, its going to be immensely top heavy, and though it might not move sideways on you, it may end up being a tipping hazard.
Messages In This Thread
glue appplication information
Re: glue appplication information
I answered this question in my first reply
Re: I answered this question in my first reply
Are you just adding one board for each glue-up?
Walk before you run
Re: Walk before you run
$12/bdft for 8/4 hard maple? Wow! *NM*
A couple of questions....
Re: A couple of questions....
Some sage advice
Re: Some sage advice
More explanation....
Re: More explanation....
Tool to smooth the top??
Knots - character or trouble?
Re: Knots - character or trouble?
All planes need the same skills
Might cause issues? You ever use a hand plane?
Re: Might cause issues? You ever use a hand plane?
Re: He is running lengthwise
Yeah, but.....
Re: Yeah, but.....
Wandering OT
suggestion
Re: suggestion
Save yourself a lot of trouble *PIC*
Re: Save yourself a lot of trouble
Re: Alternating Clamps
fatal and near fatal errors
Agree...
Re: Agree... *PIC*
weight issue
Re: weight issue
test it
More on clamping
Massive
