Messages Archive
Massive
Because it’s flooring it will have two 3/16” grooves running down the old bottoms - the space will show on the ends
Tightbond 3. a good choice
Boards will run the length. .I presume you mean the pieces to be glued will be 7 feet long ? Otherwise you will need 8' clamps.
Will there be danger of the wood sagging or splitting on the long overhang? No
When I glue how many rows should I put together at once? If you glue in sections you will need to straighten the edge of each section to glue the sections up. This operation will take some skill and a good long bed jointer or skilled hand planing. I would glue one board at a time and ensure it was near perfectly aligned. It will make smoothing the top easier. The glue will set enough to remove clamps to install a second board in 30 min.
Apply the glue with a roller? roller or paint brush A clamp every _12___ inches? How tight do I make the clamps? as tight as you can make them.
Lastly I’m hoping to not have to secure the island to the floor This assembly is going to weigh a LOT. It probably won't move.
Messages In This Thread
Help with a butcher block top
glue appplication information
Re: glue appplication information
I answered this question in my first reply
Re: I answered this question in my first reply
Are you just adding one board for each glue-up?
Walk before you run
Re: Walk before you run
$12/bdft for 8/4 hard maple? Wow! *NM*
A couple of questions....
Re: A couple of questions....
Some sage advice
Re: Some sage advice
More explanation....
Re: More explanation....
Tool to smooth the top??
Knots - character or trouble?
Re: Knots - character or trouble?
All planes need the same skills
Might cause issues? You ever use a hand plane?
Re: Might cause issues? You ever use a hand plane?
Re: He is running lengthwise
Yeah, but.....
Re: Yeah, but.....
Wandering OT
suggestion
Re: suggestion
Save yourself a lot of trouble *PIC*
Re: Save yourself a lot of trouble
Re: Help with a butcher block top
Re: Alternating Clamps
fatal and near fatal errors
Agree...
Re: Agree... *PIC*
weight issue
Re: weight issue
test it
More on clamping
Massive
