Messages Archive
Re: that is all yours
that is all yours ()
Joseph Mulherin
Bill, are you using the plywood under the table top? Cut the top angles on your saw and fit dry to see they are even, then glue up the sections to the plywood and clamp as needed.
For the table bottom and post I would round over the edges with a 1/2" router bit and sand till smooth.
Since you said the table will be used for minor eating What I have said will suffice for looks.
