Messages Archive
Re: designing a table
Re: designing a table ()
Unclear what you are suggesting. What profile is to be maintained? Are you suggesting the vertical "post" should be make of the same thickness material as the base. The answer to that design is , no. It makes the column look too heavy relative to the top thickness. Even 1 1/4" material for the column is too thick.
