Messages Archive
Re: Drill bit question
Drill bit question ()
Keith Newton
I usually grind a little flat where I start the hole.
Use caution on the exit size too, since it will break through on the sides before the middle, which will cause it to climb the bit on a fast spiral. If you have a DP vice this helps hold it down
I sometimes grind a flatter cutting edge on the face to change to more of a scraping cut to prevent breaking a bit,
