Messages Archive
Front wheel drive?
Dick Coers
Did you really clean off the rotors? I use lacquer thinner to cut the grease off new ones, I was taught to use brake cleaner but I don't keep that around. If there is a little oil on the pads now, they might be grabby. Might also just be the CV joint. Did you look it over when you had the wheel off?
