Messages Archive
Re: Grizzly Tablesaw arbor nut
Keith Newton
Maybe you didn't get it tight enough. The startup will allow the blade to slip a little until the nut tightens, which will be like hammering the wrench when the nut spins up and grabs. If you want to find out how hard it can be just leave it part way out as I did once to go answer a phone call I was expecting, then forgot it was loose when I came back out. Ever since I will never again answer the phone while making a blade change.
