Messages Archive
Ditto
I do as you do, using a cut off to set the corner registration of the piece being glued, and to check that the mitered trim is the correct angle for whatever the angle needs to be.....half of 90.3 degrees for example. I have never seen this procedure describe in detail anywhere. It is the only way I can get good miters.
