Messages Archive
Re: 5 inch pvc pipe
5 inch pvc pipe ()
John McGaw
In addition to what others have said about S&D, you will do yourself a favor if you ask specifically for fittings with wide sweep. Having sharp bends will inevitably cause problems. When I put mine together I avoided cementing every joint so that it could be disassembled later if cleaning is needed. I used short sheet metal screws at the unglued joints to hold them together although the fittings are really tight enough on their own.
