Messages Archive
Re: Sorta OT Soldering? Brass *LINK*
Hank Knight
Alan,
Solder is probably the best (simplest) way to join brass to brass. If you try to join two pieces of brass together with a brass rod (brazing), you're likely to end up with a mess since the rod and the brass workpiece have the same or almost the same melting point. If soldering is done properly, you'll have very little gray or silver solder showing. Here's a YouTube video that might help:
