Messages Archive
Re: Only if...
Re: Only if... ()
Jerry Roberts
Tell ya what I found out about my delta table saw.
about 6 months ago the male ground pin broke off the plug. I thought I could just run a wire to case gnd and temperaly run it to 3rd wire gnd. I checked the broken pin to the saw case grnd. with a meter and no continuity. Now, I don't know where that third gnd wire goes inside the saw but it don't go to case gnd. So, in case the hot wire should touch the case, that power will not go to the gnd wire and out so it doesn't go to the operator.
