Messages Archive
Why do you want to change it?
Out feed table ()
I am going to replace my fixed out feed table on the table saw with a rolling work table.
Hi CJ
You have not said why you wish to change. There is a big advantage to retaining a fixed out feed table - the floor evenness is then never an intrusive factor. Unless you need space, I believe it is advisable to keep the table attached.
Unless you are working predominantly with sheet goods, then a large outfeed table is unnecessary. I work 99% with solid wood, have a contractor saw, and the out feed table is about 12" long. That is enough for my needs.
A rather poor photo ..
If I needed more out feed space, I would only need to do so temporarily, and could make do with rollers.
What is your requirement?
