Messages Archive
If you use 3M
One method *PIC* ()
Gary Smyth
You can do a direct mount on an oversize piece of ply. By running a line through the center 12/hole/6 you can use a square to get the right angles to fit precisely the clock frame. Then you need to cut the perpendicular lines on the money, but sometimes it is easier to do it that way.
