Messages Archive
Re: How to set the fence on a saw sled
Alan in Little Washington (NC)
The problem with the tramel method is how do you reliably place its tip in the kerf made by the blade which may be 1/8" or 3/32" wide?
Don't sweat the initial placement, it is a waste of time. I just use a square to get it close, use a screw to anchor one end and clamp the other. Then I use the five cut method to get it spot on before I glue the other end. Once the glue sets I add a screw to that end as well. On my adjustable fence sled, one end pivots and the other has a zero stop. I locate the zero stop using the 5 cut method also.
