Messages Archive
Garage/Workshop walls?
Joe Pack
Time to consider interior wall material (or not).
My new building will have a 28x28 garage area. To install an interior wall or not to install? If I do, I will insulate the wall, just in case...
I will also have a 16x28 insulated shop room that will have finished interior walls. Most likely choices of wall material are drywall or OSB, based on cost. I will use several sections of 1/4" pegboard, but plan to build those seperately over 2x2 frames to keep peg hardware out of contact with the insulation. What do you see as pros and cons of these. Is there a better, fairly economical choice for workshop walls?
