Messages Archive
Alan in Little Washington (NC)
Kelley,
First, if your saw has two miter slots, the I-BOX miter bar can be set to ride in either one.
When in the setup/calibrate position (with miter bar in the right slot of my right-tilt Unisaw which is farthest from the blade) the inside edge of the miter bar is about 5.5" away from the edge of the blade. It can be moved an additional 1.5" (7" total) without the miter bar alignment plate extending past the end of the IBOX fence.
So the answer is you should have no problem using an I-BOX on your Jet Super Saw. (you can actually get a little more space if the alignment plate is allow to extend past the end of the fence.)
When deciding on fence dimensions we went to TS manufacturer websites, WW and big box stores, e-mailed friends, etc. etc. then made a spreadsheet with as many make and model TS blade-miter slot distances as we could find, certainly the major brands. While it may not fit them all, the I-BOX should fit most.
Photo showing miter bar and alignment plate:
Messages In This Thread
