Messages Archive
Re: Concrete figurine
Concrete figurine *PIC* ()
Stuart Johnson
If you have a good match between the two pieces you could drill matching holes and epoxy in a bolt. A little on the two pieces as well but don't take it to the edge. Once it's set you can mix a bit of mortar and work it into the crack. Once dry it should look good.
