Messages Archive
PurflingResponse To:
Re: Mitered plywood () Ellis Walentine
I was suggesting using solid strips of whatever your face veneers are, or a contrasting wood for that matter. If you use 1/8" x 1/8" strips, you can put a 1/8" roundover or chamfer on them. Use larger cross-section strips if you want a heavier edge treatment.
Messages In This Thread
- glue out at the corners
- Mitered plywood
- Re: glue out at the corners
- prevention is the answer
- Mitered plywood
