Messages Archive
Re: circles with the bandsawResponse To:
Re: circles with the bandsaw () Larry in NW Ohio
I`m glad you replied and let us know that the circle cutting is coming along better. If for some reason the bandsaw doesn`t work good enough for what you want to use them for and you have a belt sander, then make a simular jig for your sander. Use a board and attach it to the table and put the center pin at the distance where you need it and sand away, of if you only have a hand belt sander you`ll need to fasten it down to a table and do it a little different. Good Luck. Larry
