![]() ARTICLES & REVIEWS Excerpts from the MessageboardsJohn in
rural
Festus asked: Just
looking for a quick refresher before I tackle the mudding of our
basement this
weekend. 1) Use
all-purpose mud
because I'm new to this. Anything else
that I might
have forgotten?
Dustmaker
Mike: I
went to Lowes and got a swivel head sanding block used
for dry wall and a handle. They are only a few bucks and are worth it
IMHO.
I taped a vacuum hose to it near the
sanding block to catch the dust as it was made. Just make sure you have
a dust
filter installed in the Shop Vac because it will blow the dust all over
the
place (DAMHIKT) and it will make clean up worse. The sanding stick is
great,
especially for the ceilings. I found that regular 80grit paper worked
best for
the first couple layers. This vs. the screen type paper. The screen
just seemed
to clog up. Yes I needed the 80g because my drywall skills aren't the
best. Rob in
Spring,
Texas: Use the premix mud in the
BLUE box.
It's a bit lighter and dries quicker. Also I like to mix it with a
small amount
of water. It makes it easier to work with. If you’re really brave try
some of
the 30, 45 or 60 minute mud. Saw some pro drywall guys do some work in
my
sisters house, put up the rock, floated and textured all in the same
day.
Texture was a spray on / knock down. BubbaBob:
Use
more mud than malt/yeast based
refreshment for best results....3:1 ratio is about right. Brent
Harral: Save yourself the most
frustrating
part and use nylon mesh tape instead paper tape, especially if you
don't have a
tape dispenser (banjo). Been using the nylon for years w/o a problem.
You
really shouldn't have to sand until after your 3rd or 4th final coat.
NOW is
the time to consider crown molding in the room so you can hack the
inside
corners where the wall meets the ceiling. Second most annoying aspect
of drywalling,
IMHO ;) I do it all with a 6" knife for some reason. Lee
Schierer: You can sand without dust
using a
stiff sponge that is damp. Rinse the sponge often for best results. No
dust
ever. They sell good ones in the tile section of Home Depot. Wolf
Kiessling: I vacuumed once after
some dry wall sanding and ended up
with a bigger mess than when I started. My filter wasn't as good as I
thought.
It was the first time I ever attempted dry wall work and I didn't get
any
advice so I paid the penalty. The funny thing was, while vacuuming I
didn't
even notice the mess I was making until it was way too late. Gary
Camp: I
do sand between layers, may be a personal preference. Use
drywall sanding screen, it’s made to fit the sanding blocks and doesn't
load up
nearly so quick as sand paper. More than well worth the cost. Grant
Smith: I
do drywalling from time to time on a side job basis. Here's what I'd
recommend:
I like the
sanding sponges
if you end up having to sand. No dust. Many thin coats
are better
than one thick coat requiring sanding. Perhaps the
biggest rule
about drywalling: Buy, borrow, or
rent one of
those light trees. The kind with 2-4 halogen lights. Point them at the
wall you
are working on. Your drywall
comes out
looking LOTS better under normal room lighting if you use brighter
lights to do
the work in the first place. Tony
Laros: For the first coat I use
sandable
Sheetrock 20. I don't know if it's a Canadian product or if you have
something
equivalent in the US. It dries in about 20 minutes, so by the the time
you've
gone around the room you can start the second coat with the premixed
mud. Don't
mix too much at a time. For inside corners and at the ceiling get metal
corner
bead with paper. This will make your job look like it was done by a
pro. Beer
is OK unless you're on stilts. Angus
Barclay: I've
just finished yet another room in my house and have
found this system works for me.
John
Ergle First time I tried my
hand at drywalling,
I almost lost my religion on my first inside corner. Then I remembered
seeing
one of those "corner things" at the local Lowe's. Mad a mad dash to
the store before they closed at 9 pm, and I'll tell you, that thing is
worth
it's weight in gold. Now the professionals who just did my new house
didn't
need or use anything like that, but for amateurs like me, that thing
saved an
awful lot of time and cussing. © 2004 by the respective Authors . All rights reserved. No parts of this article may be reproduced in any form or by any means without the written permission of the publisher and the author. |
